PSoC™ 4
ErBU_1372276
First like received
I have a time of 500ms between reset and calling the main function. It is the function in start_c init_libc_array taking all this time? How to reduce this time?
I created a test project for moving only one output to test this time.
Thank you,
Eric
Bob_Marlowe
Level 10
50 questions asked 10 questions asked 1000 solutions authored
Level 10
All the programming of the internal registers which include components and wiring is done after stabilization of the clocks and PLL. All registers get a value, so setup time is independent of the components used,
In cydwr-file, System tab there is a "Device Configuration Mode" setting which allows for using more flash but faster setup.
Bob
Bob_Marlowe
Level 10
Level 10
Bob
ErBU_1372276
First like received
thank you for your help, I'll try.
ErBU_1372276
First like received
Thanks Bob,
I disable the WCO clock and now I have 5ms between reset and the main function.
Thank you again for your help.
Eric
