Spandana-S
5 sign-ins First reply posted 5 questions asked
Greetings Sir/Madam,
In our design we are using CY8C4045FNI-S412 touch MCU, can you suggest the Hardware design (touch panel) material and Layout guidelines or suggest any application note for design regrading the mentioned part number MCU.
Thanks & Regards,
Spandana.
Arpit_S
100 solutions authored 250 sign-ins 10 likes given
Hi Spandana
Please refer https://www.infineon.com/dgdl/Infineon-AN88619_PSoC_4_Hardware_Design_Considerations-ApplicationNote... for more details on PSoC 4 Hardware design considerations.
Also, You can find more details about CY8C4045FNI-S412 on https://www.infineon.com/dgdl/Infineon-PSoC_4_PSoC_4000S_Datasheet_Programmable_System-on-Chip_(PSoC...
Also, CY8C4045FNI-S412(PSoC 4000S) supports CapSense which could be used for touch related Applications.
You can find more information about CapSense on https://www.infineon.com/dgdl/Infineon-AN85951_PSoC_4_and_PSoC_6_MCU_CapSense_Design_Guide-Applicati...
Thanks & Regards
Arpit Srivastav
Arpit_S
Hi Spandana
Thanks & Regards
Arpit Srivastav
