Looking at PSoC 4000 IMO clocking. I'm using CY8C4013SXI-410.
In document:
PSoC 4000 Family: PSoC 4 Architecture TRM, Document No. 001-89309 Rev. *D
it shows Table 8-1 for IMO frequency settings using register CLK_IMO_TRIM2 with a 6-bit field. However, when referencing PSoC 4000 document:
PSoC 4 Registers TRM, Document No. 001-90002 Rev. *D
it shows a 3-bit field for CLK_IMO_TRIM2.
Which document is correct?
It looks to me like a copy/paste error from PSoC 4100/4200 doc's. Or, I'm missing something.
Bill
CLK_IMO_TRIM2
In the register TRM is shows "3-bit field". That's right.
CLK_IMO_TRIM2
Thank you.
This means Table 8-1 is incorrect for CLK_IMO_TRIM2. Where can I find the correct table?
After reading more of the Registers documentation, CLK_IMO_TRIM2 is not used to set the IMO output frequency in 4MHz steps. The correct register is called CLK_IMO_SELECT. So, the text description in "PSoC 4 Architecture TRM, Document No. 001-89309 Rev. *D", section 8.2.1 Internal Main Oscillator, is referencing the wrong register. Can you confirm this for me? Thank you.
