- Email to a Friend
Dear Sirs and Madams,
We are considering LIN communication for PSoC4S MAX.
Since ModusToolbox 2.4 doesn't have a LIN sample project, I found the following sample project on GitHub.
mtb-example-psoc4-lin-slave project URL
https://github.com/Infineon/mtb-example-psoc4-lin-slave
We understand that this sample project is written for CY8CKIT-041-41XX.
When I make "import applications" this project downloaded from Github with ModusToolbox 2.4, the "Tool" items such as "Device Configurator" are not displayed .
What modifications are needed to take advantage of this project and make it available on PSoC4S MAX?
Is it possible to provide a LIN sample project that runs on PSoC4S MAX?
We have tried various things with reference to main.c of this LIN sample project, but it is not working well.
I have a question regarding the following, which is declared on line 151 of main.c.
mtb_stc_lin_context_t lin_context;
Does this structure do not need to be populated with initial values before reference?
I understand that the following in main () is related to LIN initialization.
(a) line 272 : l_sys_init ()
(b) line 281 : l_ifc_init ()
l_ifc_init () → cyhal_uart_init () → _cyhal_uart_setup_resources ()
This sequence of actions will not be processed properly and an exception will be raised.
Specifically, the return value of _cyhal_uart_setup_resources () is CYHAL_UART_RSLT_ERR_INVALID_PIN (0x4021e00). (cyhal_uart.c return on line 381)
Is there a shortage of generated sources?
PSoC 4 MCU
- Email to a Friend
Hi @MaMi_1205306 ,
I tried cloning the code-example from the link which you have mentioned here : https://github.com/Infineon/mtb-example-psoc4-lin-slave . I tried following the below steps -
1. Using modus-shell, perform "make getlibs" and then "make eclipse" one after the one in the 'mtb-example-psoc4-lin-slave' folder which you have cloned as CE. This process will take few minutes.
2. Open "Eclipse IDE for Modus Toolbox 2.4" and create a workspace.
3. Go to File -> Open Projects from File System -> Browse to your CE folder -> Open.
4. Click on the project in the workspace.
5. Click on "Refresh Quick Panel".
And below as the image shows, all the configurators appear under the tools section-
Please follow the above steps and let us know in case of any further query.
Aashita
- Email to a Friend
Hi @MaMi_1205306 ,
Aashita
