Dear Sirs and Madams,
Please tell us about the contents described in the application note AN85951.
AN85951 - PSoC® 4 and PSoC® 6 MCU CapSense® Design Guide URL
https://www.cypress.com/file/46081/download
Section 7.4.2 contains the following :
"You should use flex circuits with thickness 0.01 inches (0.25 mm) or higher for CapSense."
What does the 0.01 inch shown in this sentence mean?
Is it the thickness of the flexible substrate?
Or is it the thickness of the copper foil on the flexible substrate?
We would like to know what 0.01 inch refers to.
PSoC 4 MCU
The 0.01 inch is the total thickness of the flex PCB - the thickness of the flexible substrate. The regular copper thickness can be added to this.
Hari
Hari
Hari-san,
Thank you for your response.
I understood your answer.
However, We think that the thickness of a general flexible substrate is generally "12.5 to 25 um" or "0.5 to 50 mil".
カバーレイ(の)層:Coverlay layer
(カバーレイの)接着層:Adhesive layer
銅箔(の)層:Copper layer
ベース(材の)層:Base layer
厚み(理論値):Thickness (Theoretical value)
0.01 inch = 0.254 mm
I think 0.01 inch is an order of magnitude different, but what about it?
Does that mean that the use of thin flexible boards is not recommended?
Please confirm again.
That design would be fine. The total thickness in this case as well comes up to 0.1mm for the flex PCB and this design is supported by CapSense. We have flex kits that are of the same dimension and it will work reliably.
I will work with our documents team to get the AN updated with the right value. Thank you for pointing this out...
Hari
