Dear Sirs and Madams,
Please tell us about the accuracy of ECO used for PSoC4S.
We are currently using 24MHz external clock for my PSoC4S(CY8C4126AXI-S445).
(1)
The frequency setting described in Architecture TRM is "24MHz ≧ f > 17MHz".
Please tell us the acceptable ECO accuracy for this specified upper limit of 24MHz.
(2)
If I exceed the specified upper limit of 24MHz, will it affect the operation of PSoC4S?
PSoC 4 MCU
- psoc4 mcu
Hi @MiNe_85951 ,
I am looking into the documents.
You can refer to the below document section 7. Cypress Recommendations for External Crystal Oscillator (ECO) for more details on ECO.
https://www.infineon.com/dgdl/Infineon-AN95089_PSoC_4_PRoC_BLE_Crystal_Oscillator_Selection_and_Tuni...
Thanks and regards,
Sidramesh
Sidramesh-san,
Thank you for your support.
I have already reviewed this application note.
However, I thought that the content described in this application note was information about BLE devices.
Does it have to be within the below +/- 20ppm listed in Session 7 even for PSoC4 devices without BLE?
Hi @MiNe_85951 ,
If your ECO is more accurate than IMO then no problem ECO frequency should be between 4 to 33MHz.
If it is less accurate then there are timing constraints for some blocks you have to make sure of that much accuracy.
Thanks and regards,
Sidramesh
