PSoC™ 4 Forum Discussions
MaMi_1205306
Level 7
Level 7
500 replies posted 50 solutions authored 25 likes received
Dear Sirs and Madams,
We are considering MagSense.
We refer to AN219207 of the application note.
AN219207
https://www.cypress.com/file/427771/download
Is it possible to get the projects listed in the appendix B of this application note?
If possible, please also provide an <Project name>.iic file and <Project name>.ini file.
TakashiM_61
1000 replies posted 500 solutions authored 750 replies posted
It seems the project described in AN219207 Appendix B is not in public (as CE).
Will check it again...
Takashi-san,
This application note that makes CY8CKIT-148 work easily,
I think that it may be a project pre-installed on CY8CKIT-148.
Please investigate this project and iic/ini files.
Again, the CE introduced in AN is not in Public.
In AN219207: https://www.cypress.com/file/427771/download​,
Page 46, figure 52,  you would find the command that is to be entered in BCP to receive data.
Page 45 of AN, shows how to set the variable settings.
regards,
Takashi-san,
Thank you for your confirmation.
However, it was troubled very much.
I don't have the pre-installed CY8CKIT-148 at hand.
Once you have written the program, this project can never be verified.
Also, the command line for the specified image is only displayed halfway.
I guessed and entered the command line,
Rx8 [h==0d 0A] @1rc @0rc @1avg @0avg @1bl @0bl @1status @0status @1dc @0dc @1alpStatte @0alpState [t=00 ff ff]
There is a problem that data cannot be received normally.
Therefore, this application note is unfriendly and you may not want to publish it.
