PSoC4100SP:SPI(Master) Slew rate slow
RyYo_1406951
100 replies posted 50 replies posted 25 replies posted
Please answer below.
The same question is written in English and Japanese.
・English
https://community.cypress.com/message/199089
Continues the above thread.
The waveform appears to be a signal that switches faster than 1 MHz.
Is it OK to set Slew rate to Slow?
・Japanese
上記スレッドの続きになります。
頂いた波形は1MHzより早く切り替わる信号に見えます。
Slew rateをSlowに設定して問題ないのでしょうか?
Ekta
750 replies posted First like given 250 solutions authored
Hello
Yes, it is OK to set the Slew rate to slow, if the rise and fall time of the waveform after setting the slew rate to slow meets your specifications.
Best Regards
Ekta
Ekta
Hello
Best Regards
Ekta
Ekta-san
Thank you for your answer.
