Below, the same sentences are written in English and Japanese.
・English
I want to identify the cause of the error when a reception error occurs in LIN Slave.
(Possible error cause → bit error, checksum error, parity error, sync data error, bus error,etc)
If you check which API and register, can you check the cause of the error?
・日本語(Japanese)
LIN Slaveで受信エラーが発生した際に、エラー要因を特定したいです。
(考えられるエラー要因→ビットエラー、チェックサムエラー、パリティエラー、Syncデータエラー、バスエラー等)
どのAPI,レジスタを確認すればエラー要因確認できますか?
You could refer to Handling Error for Unconditional Frames section of Local Interconnect Network (LIN) Slave Component User Guide for PSoC - KBA225227
It also provides a code snippet to monitor the error status register. I hope this helps.
Shanmathi
Shanmathi
Thank you for your answer.
