Mar 04, 2019
12:28 AM
Mar 04, 2019
12:28 AM
When executing the API of InitializeAllBaselines, which value of BaseLine is set?
①RawCount
②RawCount(After executing software filter)
01:35 AM
Mar 04, 2019
01:35 AM
Hi, as the name suggests it is only the initialization of baselines. If you require the software filters enabled to be executed, pls use UpdateAllBaselines API.
You could refer to CapSense component datasheet for more details.
Shanmathi
