Are the PSoC4 CY8C4247AZI-M485 and the CY8C4248AZI-L485 pin for pin compatible? Is the CY8C4248AZI-L485 a drop in replacement for the CY8C4247AZI-M485? I have a board designed for the CY8C4247AZI-M485 and finding out more RAM is needed.
Also, the CY8C4248AZI-L485 has USB pins that are no-connects on the CY8C4247AZI-M485. My board is designed already. If the CY8C4248AZI-L485 is a drop in replacement for the CY8C4247AZI-M485, what should I do with the USB pins? Just disable these USB pins? Thanks.
Hi @es ,
The parts CY8C4247AZI-M485 and CY8C4248AZI-L485 are pin to pin compatible. The PSoC 4200 L part can be used as a drop in replacement for CY8C4247AZI-M485 device. You can leave the USB pins unconnected in the PSoC 4200 L part since you are not using USB.
Just to confirm once, change the device to the PSoC 4200 L part in the PSoC Creator and ensure that the project builds fine without any errors . This ensures that there is no schematic error.
Bragadeesh
Hi @es ,
Bragadeesh
