HI,
I have been working on a project using PSoC4 and RF modules NTX0 and NRX0 (27Mhz), I have to send a data byte and receive it at the receiver.
I am attaching my project, please have a look and let me know how to;
1.Set the RSSI according to the threshold using ADC
2.Show the communication using Putty?
Thank you,
Arshiya Tabassum
Your project is not attached correctly. Right Click on the project name-> Archive workspace -> Attached the zipped files again.
1) RSSI is the RECEIVED Signal Strength Indicator , the signal strength varies based on the output TX power set by you.
2) Yes , you can use a UART SCB component in your project to send the data to serial terminal. Also you need an external UART-USB converter. If you are working on PSoC 4 Pioneer Kit , the on board kitprog will do the UART-USB conversion. If you are working on your custom board with only PSoC chip , you have to use a external UART- USB converter ( KitProg, FTDI etc).
-Gyan
-Gyan
Potentially, you can setup an RS cable to receive the UART and spit it to the PC, but that will take about as much work as a UART-USB converter setup.
