Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
masu_1341616
Level 4
Level 4
5 solutions authored First like received 10 likes given
Have you been to adopt PSoC4 USB as HID on "Windows Touch".
Did you have any limitation or issue?
PSoC Creator (with PSoC 4L series) has the Code Example of USBFS_HID.
It could be a reference (or starting point) for what you wants...
thanks.
masu_1341616
Level 4
Level 4
I'm sorry, I didn't explain it enough.
It is using resistive touch panel.  PSoC4 translate touch cordinates as USB HID to send PC(Windows Touch).
could you please help us to understand more clearly what you want to know?
And, you mentioned "any limitation or issue". Which kind of limitation or issue do you want to foreseen (if anything exists)?
thanks.
Sorry late reply.
We will use USB of PSoC4L series.
Could it set "digitizer" of touch screen with HID to USB component?
thanks.
