FUHU_4360921
First like received
Dear Sir,
I use CYBL10573 to driver LED matrix 8COM x 7 SEG, but I only find there are LCD Driver for 4COM, what is better way to driver the LED matrix?
Thanks!
kwan
Hi Moto,
Thanks for your help! I put the code into 1khz interrupt routine, it work well,
void led_1khz_func(void)
  uint8_t vdd;
    led_gnd_off(led_timer++);
    led_timer%=LED_GND_NUM;
    vdd = gd_led_matrix[led_timer];
    LED_PA_Write((vdd&0x01)?LED_VDD_ON:LED_VDD_OFF);
    LED_PB_Write((vdd&0x02)?LED_VDD_ON:LED_VDD_OFF);
    LED_PC_Write((vdd&0x04)?LED_VDD_ON:LED_VDD_OFF);
    LED_PD_Write((vdd&0x08)?LED_VDD_ON:LED_VDD_OFF);
    LED_PE_Write((vdd&0x10)?LED_VDD_ON:LED_VDD_OFF);
    LED_PF_Write((vdd&0x20)?LED_VDD_ON:LED_VDD_OFF);
    LED_PG_Write((vdd&0x40)?LED_VDD_ON:LED_VDD_OFF);
    LED_PH_Write((vdd&0x80)?LED_VDD_ON:LED_VDD_OFF);
    led_gnd_on(led_timer);
I am still looking for some hardware solution instead of the software interrupt to occupy the CPU resource!
Thanks!
kwan
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
I wrote a couple of 7SEG LED samples for PSoC 4,
although the numbers of COM x SEG are different
I hope that they could be a starting point sample.
https://community.cypress.com/message/191467
https://community.cypress.com/thread/45701
moto
MotooTanaka
Level 9
Level 9
I just tailored the second sample for 8 coms without UART type.
I only confirmed that this project is compile-able,
but as I don't have a hardware with this PSoC(PRoC?),
I could not have tested it.
And also I have not assigned any particular pins, so please assign pin according to your hardware.
The schematic is now
moto
Hi Moto,
  uint8_t vdd;
Thanks!
kwan
