Feb 24, 2015
03:19 AM
Feb 24, 2015
03:19 AM
Hi All
I am working on a project in which I need to implement a Master Device (Pioneer Kit) and a Slave Device (Prototyping Kit) that communicate with each other through I2C. I have designed two different projects named I2C_MASTER1 and I2C_Slave that are attached here inside a zip file called I2C_Comm (1). The functionality that I want to implement is as below:
1. The master sends a character to the slave thorugh I2C.
2. The slave receives the character and does some process on it.
3. The master reads the processed character from a slave and then sends it to PC using UART.
I am not getting the desired results as of now. Anybody working in this direction can guide.
Thanks and Regards
Shaunak
