PSoC™ 4 Forum Discussions
Andreas_Heder
50 sign-ins 10 questions asked 10 replies posted
i have a problem in getting up FreeRTOS for PSoC4:
the vTaskDelay(pdMS_TO_TICKS(500)); -> never return
MainTask runs only onces.
Main_Task_2 is working as aspected.
all Libs are up to date.
Have anybody a sample Project for PSoC4 and FreeRTOS I am wondering that is no Example availible?!
BR
Andreas
LeoMathews
100 sign-ins 25 solutions authored 100 replies posted
Hi @Andreas_Heder
Currently, we do not have an example project for PSoC4 with FreeRTOS with new libraries. I will try from my end to create an example project for PSoC4 with FreeRTOS with new libraries.
Thanks and Regards,
Leo
LeoMathews
Hi @Andreas_Heder
Can you please refer to this link: Example project for PSoC4 and FreeRTOS and check if it helps?
Thanks and Regards,
Leo
Andreas_Heder
Hey @LeoMathews
i already read this but it is not helpfull because it was made with PSoC Creator.
I am testing it with MTB 3.0 and VS-Code. Could you provide an Example Project for PSoC4 with FreeRTOS based on MTB3.0?
BR
Andreas
LeoMathews
Hi @Andreas_Heder
I have attached a sample project(LED blinking) for PSoC4 with FreeRTOS for the CY8CKIT-041S-MAX kit based on MTB 3.0. I have referred to this link for the creation of this project.
Thanks and Regards,
Leo
Andreas_Heder
Hello, @LeoMathews
ok the Example work as it is.
But:
1. it was made with MTB2.4 (should not be a problem)
2.this based on old Versions from:
-core-make 1.9.1
-mtb-pdl-cat2 1.6.1
-recipe-make-cat2 1.2.2
when i try to update (all or seperatly) the build process does not work anymore.
When i try to make a new Project, newest Libs, copy and paste FreeRTOS files... same result as before.
Could you be so kind and provide an Example which was MADE with MTB3 (not only testet) and has the newes Libs?
BR
Andreas
LeoMathews
Hi @Andreas_Heder
Thanks and Regards,
Leo
LeoMathews
Hi @Andreas_Heder ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Leo
