suno_285741
First solution authored 10 questions asked 5 replies posted
Hello
I had used CY8C4124LQI-433.
I have some Capsense Applications. That works well.
These Application compiler optimization is speed.
Flash size of application is 11KB.
I want to add bootloader. but bootloader code size is 5KB. it is too mush to use 16KB chips.
I need to use Compiler optimization for code size.
I had checked optimization code size. It is 13KB.  It is suitable for my application.
Have you ever size optimized your CapSense and Bootloader application?
Is there any problem to use this?
Thanks!
Rakshith
Hello suno_285741​,
Ideally, the optimization levels should not be causing any issue with the CapSense or Bootloader source files and I am not aware of any known issues.
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Hello suno_285741​,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
