Dear Sirs and Madams,
Regarding the contents of application note AN84858, I understand that I am using PSoC5LP as a programmer and programming to PSoC4.
( HSSP : PSoC5LP => Target : PSoC4 )
So I have some questions about this application note.
(1)
Is there an application note that uses PSoC4 instead of PSoC5LP as a programmer for programming PSoC4?
( HSSP : PSoC4 => Target : PSoC4 )
(2)
If not, is it possible to provide the HSSP sample code for PSoC4 or the content to change from PSoC5LP to PSoC4?
If PSoC4 cannot be used for HSSP, please let us know if there is any reason.
(3)
Also, are there any application notes for programming PSoC5LP with PSoC5LP as a programmer?
( HSSP : PSoC5LP => Target : PSoC5LP )
PSoC 4 MCU
And this KBA may be of some interest. KBA93541
Using the CY8CKIT-049 to Program Another PSoC® 4 -... - Infineon Developer Community
Hi @MiNe_85951,
We do have an application note for programming the PSoC 5LP target with a PSoC 5LP device using HSSP - AN73054. The AN also mentions the steps that need to be followed to port the application to another host programmer (please refer to Section 3. Porting the HSSP Application to a Host Programmer). We will check internally if we have an example project that uses PSoC 4 as the host and get back to you.
Rakshith M B
Dear All,
Thank you for your response.
I'm very grateful for providing information about HSSP.
First of all, we will start considering based on the information you received.
