Hello, I've used the PSOC 4 and PSOC 5 and like using the PSOC Creator IDE for code development. I've now stumbled on the GUI generation with the PSOC microcontrollers. I want to learn more, can anyone tell me what software I need in order to create GUI's for the PSOC 4 and 5? Are there any videos on the steps to create GUI's? Kinda like the PSOC 101 videos on youtube.
Thank you
joli,
Segger AppWizard is not needed to create GUIs using emWin. It just makes the effort easier. I haven't used the AppWizard but I assume it uses the PC to visualize the GUI and generate much of the operational code to be ued with emWin.
emWin is not needed to create GUIs on the PSoC5. It just makes the effort easier. I've used emWin with the PSoC5 and PSoC6. I've made my own GUI objects. It was a bit more coding trial-and-error.
Hi @joli_601446,
Can you please let us know which display and PSoC development kit are you using for creating GUI's for the PSoC 4 and 5?
Warm Regards,
Gautami J
Hello, I don't have a kit or display yet, I just want to learn how to generate a GUI using emWin or the Seggar Wizard. I'm planning for my next design.
Thank you
Joe
I can purchase a kit, no problem. Let me know which one would be good to start with.
Thank you
Hi @joli_601446,
I would suggest you to buy PSoC™ 6 Wi-Fi Bluetooth® pioneer kit and CY8CKIT-028-TFT display.
To generate a GUI using emWin or the Seggar Wizard in ModusToolbox™ software v2.4 . We have a inbuilt code example in ModusToolBox software that demonstrates displaying 2D graphics on a TFT display using the emWin graphics library and the AppWizard GUI design tool in FreeRTOS. The application initializes the system peripherals and creates a task that cycles through demo images in response to button presses.
You can create this project directly by selecting PSoC6 emwin tft freetos template from Project Creator .
Please follow mtb-example-psoc6-emwin-tft-freertos to know more about PSoC6 emwin tft freetos code example.
Warm Regards,
Gautami J
Thank you very much. I'm not an expert with FreeRTOS, is that needed to make an application that uses a GUI?
Joe
joli,
Cypress never developed a PSoC5 development kit with a TFT display. This is why there are no Cypress-official examples on doing this.
Using the PSoC5 with a TFT display is definitely achievable.
Here are links to what I found on the internet using a quick search:
- PSoC-5LP-ILI9341-240x320-TFT-LCD
- What-LCD-screen-to-use-with-a-psoc-5lp-059-to-create-an-LCD-oscilliscope
- LCD-interface-questions-SPI-Graphic-interface
- uGUI-PSoC-5-sample-with-SSD1963-LCD-Controller
- PSoC-ILI9341
- https://www.youtube.com/watch?v=sf-Zm8xbTb8
There are probably more references.
I hope this is a good start.
Hello, thank you very much for the information on the PSOC5. I might have an opportunity to use the PSOC6 in the future. Is the emWin or Segger AppWizard required to make GUI's for the PSOC5?
Thank you
joli,
Hi @joli_601446
The mtb-example-psoc6-emwin-tft-freertos emwin tft freetos code example supports PSoC 6 device. please refer to the screenshot.
This code example also requires CY8CKIT-028-TFT .TFT is a display shield board.
Warm Regards,
Gautami J
