PSoC™ 4 Forum Discussions
JoBr_1593366
100 sign-ins 50 questions asked 100 replies posted
You have a video of this board http://www.cypress.com/video-library/PSoC/cypress-psoc-4200l-audio-solution-introduction/480396
and have sent me firmware, etc in the past, but how do we obtain the board?
Roy_Liu
1000 replies posted 500 solutions authored 5 questions asked
The board is not for sale. You will have to build your own board.
Roy Liu
Vison_Zhang
250 solutions authored 10 likes given 500 replies posted
This seems an internal board not for sale, PSoC4-L DVK CY8CKIT-046 http://www.cypress.com/documentation/development-kitsboards/cy8ckit-046-psoc-4-l-series-pioneer-kit  also can support this USB Audio Solution with CapSense interface control, It can be purchased on official web,
Yes, I have CY8CKIT-046, but it's not directly compatible with this project, it uses CY8C4248BZI-L489 instead of CY8C4248AZI-L485 and has different pinouts
I recommend you contact the guys who provide firmware to you (if it is a CY internal person)  directly and check if they can provide you on pcs in privacy.  Transplant in different devices in easy to realize in Creator, and CY8CKIT-046 itself provide an USB audio solution demo with source code
It was provided through MyCases Technical Support, but that doesn't seem to exist anymore.
It actually has a different CODEC, so it can't be adapted easily at all.
  • CY8CKIT-046 uses WM8731.
  • PSoC 4200L USB Audio Solution Demo 630-60255-01 uses CS42448
Roy_Liu
Roy Liu
