I am working with PSoC-4 and want to know what is the PSoC-4 boot time. How much time it take for executing the first line of main() upon power-up. I could not find this data from Cypress website.
Please help.
Kurian Polachan
PSoC 4 MCU
Hello.
No bootloader, running 48MHz, "Release" application, 2.46 milli-seconds time from power ON reset to GPIO first write.
Most of this time is spent executing the SROM code which is booting the ARM processor, initializing hardware and looking at SWD programming interface. You can find this detailed in the CY8C4xxx Programming Specification, Section 4.3.
https://www.infineon.com/dgdl/Infineon-CY8C4xxx_CYBLxxxx_Programming_Specifications-Programming+Spec...
Hope this helps.
I don't think the boot completion time is specified because the boot process depends on the components used and the number of GPIOs.
1. Power on
2. Reaching POR release voltage (0.8V to 1.5V)
3. Start BOOT processing
4. main function
5. Pin_Write (1)
Since it becomes the above flow, place the API of Pin_Write (1) at the beginning of the main function.
In other words, you can measure the approximate boot processing time by measuring the period 2 and 5.
Can you provide the best case (minimum) boot up time one can achieve with PSoC-4
Hello.
Hope this helps.
