I am planning to design Multi Channel Audio Mixer + Summing unit which will take audio tracks/signals from different sources/instruments and mix/sum/block some or all the signals to outputs with PSoC Amux (into 2 Channel mixed audio outputs)
I would appreciate if someone can share some additional electrical characteristics of Amux, what I am looking for is not available on this datasheet
https://www.cypress.com/file/127201/download
It says only this :
DC and AC Electrical Characteristics The AMux operates at all valid supply voltages.
Here are my queries -
1. How much current can Amux paths carry ?
2. Can Amux route isolated signals ? ( signal sharing no common ground with PSoC Chip, kind of like EM relay )
3. What is the trace resistance from input to output through Amux ?
4. Does Amux switching cause audio level noise ?
5. What is the Parasitic Capacitance of Amux circuits ? (to avoid unwanted RC filters)
6. Can Amux carry AC audio signal below PSoC Vss Voltage (Gnd) ?
I have been trying this with two different audio sources (laptop and phone) playing two songs
It somewhat worked with few issues as follows :
1. Signal bleeding/cross-talk from some of the channels
2. Signal Attenuation/Loss of gain
Otherwise, the audio mixing and blocking did worked
Analog pins are set as Strong Drive
Amux is set with Maximum Isolation
Opamp is set for High BW/Power, Medium Cap Compensation
SW is an Input switch for enabling/disabling one or all input audio lines
LED blinks to indicate input combinations
#include <project.h>
int main()
AMux_Init();
Pre_Amp_Init();
CyDelay(200);
for(;;)
while(SW_Read()){LED_Write(1);}
AMux_DisconnectAll();
while(!SW_Read())
{LED_Write(1); CyDelay(50);LED_Write(0);CyDelay(50);}
if(SW_Read()==0)
for(int j=0;j<2;j++)
LED_Write(1); CyDelay(200);LED_Write(0);CyDelay(200);
AMux_Disconnect(1);AMux_Connect(0);
if(SW_Read()==0)
for(int j=0;j<4;j++)
AMux_Disconnect(0);AMux_Connect(1);
if(SW_Read()==0)
for(int j=0;j<6;j++)
AMux_Connect(0);AMux_Connect(1);
if(SW_Read()==0)
for(int j=0;j<10;j++)
AMux_Connect(2);AMux_Disconnect(1);AMux_Disconnect(3);
if(SW_Read()==0)
for(int j=0;j<12;j++)
AMux_Connect(3);AMux_Disconnect(0);AMux_Disconnect(2);
if(!SW_Read())
for(int j=0;j<8;j++)
Message was edited by: ShHo PSoC Sch added and some of the experimental finding are listed.
PSoC 4 Architecture
Hi Hossain,
This is not characterized. Could you let us know your requirements ?
Amux switches will be defined with respect to PSoC VSS and VDD
Kindly use the ohm meter tool in PSoC Creator(CYDWR-> Anlog tab). Search in help for more details.
Amux switching is done using connecting and disconnecting
This also we might not have characterized. Are you facing any specific issues with your design ? Kindly let us know.
This will not be possible as the device is not expected to work on this range.
Vasanth R S
Hi Hossain,
Vasanth R S
