NXTY_Tatebayasi
Distributor - NEXTY (Japan)
50 questions asked 25 likes received 250 sign-ins
Hi,  community
I was looking at the datasheet and was wondering why the current flowing in Deepl sleep mode for PSoC4000S is 2.5µA(typ) and max 60µA?
Since most of the peripherals are stopped in Deep sleep mode, I figured that the inherent design effects are almost negligible.
What is the reason or idea behind the data variation?
PSoC 4000S Data Sheet
Chihiro Tatebayashi / NEXTY
Len_CONSULTRON
Level 9
Level 9
@NXTY_Tatebayasi ,
As @Rohan136 pointed out, the variation is due to temperature range.
Normally, the higher current (60uA) will be at the higher temperature (85C).   This is because silicon junctions tend to leak more at higher temps.   Also, the internal configurations of analog circuits, tend to be more prone to leakage and 'sneak' paths due to current biasing.
Therefore, if during deep sleep you can make sure the all analog circuits are turned off (such as LPCOMP), then your risk of 60uA @ 85C is lower.
Also, if your application is not going to see the higher temps, you can estimate a lower sleep current.
Len
Rohan136
100 replies posted 25 solutions authored 10 likes received
Hi @NXTY_Tatebayasi ,
As mentioned in the data sheet. The varying value in the current is due to temperature range mentioned.
Rohan
NXTY_Tatebayasi
Hi, @Rohan136
I appreciate your response.
The latest datasheet listed the conditions that is helpful information.
Thank you for  the update !
Len_CONSULTRON
Level 9
Level 9
@NXTY_Tatebayasi ,
Len
NXTY_Tatebayasi
Hi, @Len_CONSULTRON
I appreciate all the help you have given me.
I was able to understand the concept of max current consumption!
