ryma_2948791
I consistently see that the start address I am intending to write to is shifted by 64 bytes and cannot understand why.
Using 'Em_EEPROM_Init', I set the start address to 0x7000 (EM_EEPROM_Init(0x7000))
I do a simple write to memory using the EEPROM API's, run the program, and then read the contents of FLASH and see the information is being written to 0x7040 instead of 0x7000.
Does anyone know why this is?
Ekta
750 replies posted First like given 250 solutions authored
In order to store data at a particular address in case of EM_EEPROM please follow the steps provided in the section " Placing EEPROM Storage at Fixed Address " (page 3) in the EM_EEPROM component datasheet (https://www.cypress.com/documentation/component-datasheets/emulated-eeprom ).
This requires modifying the Linker script. Here you need to add the absolute address in flash where the EEPROM should start as well as the name of the section where the EEPROM storage will be placed.
Let me know if you face any difficulties with the same.
Ekta
Ekta
Ekta
