Hello everyone,
I am facing this issue with the CapSense tuner that I cannot seem to troubleshoot.
Is there any solution for this issue.
I added screenshots below of the configuration parameters for both the Tuner and EZI2C
Hi @MbK ,
Can you please confirm if there's any other instance of tuner is opened?
Also, Can you please try programming again and open tuner from the same project:
Right Click on the Project > ModusToolbox > CapSense Tuner
Kind Regards
Arpit Srivastav
Hi @Srivastav ,
I have opened only one instance closed all other but I am getting this issue. I tried the same as explained in the comment still not able to understand why I am getting error.
thanks and regards,
MbK
Hi @MbK ,
I'd recommend you to import existing PSoC 4100S MAX CE and see if you're able to open CapSense tuner or not? If yes, then I believe there is some issue with the EZI2C. Can you compare your code with the CE's EZI2C implementation and see if you missed something there?
Also, I'd recommend you to go through https://community.infineon.com/t5/PSoC-4/PSoC-4-CapSense-Tuner-There-was-an-error-reading-data-from-... this thread.
On top of that, Please make sure you have configured the I2C lines correctly and The same SCB block is not being used anywhere else.
Hope this helps! Let me know if you have any other issues.
Thanks!
Kind regards
Arpit Srivastav
Thank you so much!
