user_4621631
First like given
I'm trying to follow "Pairing and Bonding with a Fixed Passkey" in document "EZ-Serial BLE Firmware Platform User Guide".
I'm stuck when I get error response for command SSBP:
TX-> SFPK,P=1E240
RX-> @E,000B,ERR,E=0203
I tried setting this on peripheral and central side and I tried calling it when connected to a remote peer device and when CYSPP is not running.
Is there any specific configuration I should set before calling this command?
Is there any description of error codes available?
Yugandhar
1000 replies posted 5 likes given First comment on blog
Are you using the latest version of EZ Serial .hex file ? If not, please use the latest EZ-Serial BLE firmware from this link.
The error code ('0x0203' – EZS_ERR_PROTOCOL_UNRECOGNIZED_COMMAND) will be generated when the Command group/method is not valid or unrecognized.
P Yugandhar.
Yugandhar
P Yugandhar.
On FW version 01000215 it failed to work, but on FW version 0101011A the command works.
Thank you!
