PSoC™ 4 Forum Discussions
AmMa_2724956
First like received
I wanted to know if we can access the 'ANT' pin of a PSoC module, suppose say CYBLE-022001-00.
In the above module they have used chip antenna.
So can the ANT pin of the chip module be used as per our needs, like for external antenna?
Ameya.
GuhapriyanT_31
First like received
Hi Ameya,
The ANT pin of the PSoC4 BLE in CYBLE-022001-00 is hard wired to the chip Antenna used in the module (through the matching network). It is not brought out on any of the module's Pads. Such a provision for connecting to external antenna is available in some of our Extended range BLE modules like (CYBLE-202007-01) .
Guha
GuhapriyanT_31
First like received
Hi Ameya,
Guha
