PSOC4L - extclk is only p0.6. What is special about p0.6?
MiRo_263836
100 replies posted 50 likes received 50 replies posted
I can bring in a clk on any GPIO and use it as a digital signal clock, but there is a block in the clock wizard called ExtClk and only P0.6 is possible there.  Is this a better pin to bring any external clock in on?  Is it a direct, low capacitance line to the clock block?  I can't find anything in the TRM or datasheet that explains it.
Why have the ExtClk block with P0.6 as the only choice?  Otherwise, it is just another digital signal into the clock tree / mux. There is nothing in the datasheet or TRM to address this.
MiRo_263836
Here is a screen shot of the Clock Wizard.
Vison_Zhang
First comment on KBA 750 replies posted 250 sign-ins
P0.6 have no special, just designed as an EXT_CLK pin and it can be routed to the main clock network via internal digital routing and mux.
The chip is just designed like that, no special reason. Not just PSoC4A-L, other PSOC4 family parts which support EXT_CLK function also only designed one dedicate pin for the clock routing.
The datasheet mention the function of P0.6 in Pinouts tables, described as "srss.ext_clk:0 ", but seems this is not clear to customer. I will report this issue to document apartment to change that.
I guess that it saves you from having to put a pin on the schematic, add a wire and give it a name. Then selecting that name in the Clock Wizard.  You can just the box of the EXT CLK block and put a clock on P0.6.
