David_Zhang
Distributor - Arrow(GC)
First comment on blog First like received 50 sign-ins
Dear  Cypress:
       if  we  want to design a  touchpad, can you help to provide the relationship between touchpad size and  channel number, for example  in 5*5cm touchpad size, what number of channel  should we need?
and For larger , 10*10cm ,What should we do ?
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
Pattern design:
  • 25-mm
    diameter round touch area;
  • 5x5
    sensor scan;
  • Pitch = 5 mm;
  • Gap = 0.15mm~0.22mm;
  • Bridge width = 0.1mm~0.15mm.
具体的 sensor number需要自己计算。
LinglingG_46
Pattern design:
  • 25-mm
  • 5x5
    sensor scan;
  • Pitch = 5 mm;
