PSoC™ 4 Forum Discussions
user_3568726
First like given
I want to creat a custom component, when i edit component schmematic, I can not find digital catalog in Cypress Component Catalog,like the first picture below, but when i creat a new peoject, digital catalog can be found in Cypress Component Catalog,just like the second picture below.  please help me,thanks!PSOC3.jpgSOPC2.jpg
GyanC_36
250 replies posted 100 replies posted 50 replies posted
Hello wangshuguang81_3568726 ,
    The newly created component will be available in the 'Default' tab of Component Catalog ( As shown in Picture 1).
Please note that either you have to copy/paste the newly created Library components to your project OR you have to give the dependency of the Library component to your project. ( Right Click on the Project -> Dependency ->Check the new Library ).
-Gyan
GyanC_36
-Gyan
odissey1
Level 9
Level 9
wangshuguang,
Right-click on component symbol background and select  Properties (at the bottom of menu). Then in the Catalog Placement type the path for a component. It is a convention to start path with '/Community', following with '/Digital' (or /Analog, or /Communication) but you can make any other names. Remember that the Path must be ended with '/'
/odissey1
i have solved this peoblem, thank you all the same.
user_3568726
First like given
i have solved this peoblem, thanksvery much
