Hi Expert,
We use your PSOC4 Capsense make a product for liquid level check, we found the the test is not good when the plastic box wall is bigger than 2mm thick. There are only 0.5% rate of ADC value changed. But for little thickness(<0.5mm), there are 10% change rate of ADC value .
We have below questions?
1. What is the max thickness of plastic box wall for this Capsense liquid level test.
2. Can we get a design to satisfy this bigger thickness liquid level test with tuning the Capsense sensor pad bigger or other trick?
CY8C4246AZQ-M443 + Capsense CSD mode.
As your comments "0.5% rate of ADC value changed" and "14bits resolution", is rawcount changed with liquid around 82 counts?
If possible, I suggest you to make GND pad in the liquid. It could increase the signal.
Brandon
