I currently have a CYBLE-214015-01 module which I plan to program, and I just bought a CY8CKIT-042-BLE-A.
May I know if I am able to use the baseboard as a debug tool to debug my CYBLE-214015-01 module?
If so, how? Can I just connect the SWD pins of the baseboard to the CYBLE-214015-01 module?
Also, are the codes transferable from the CY8CKIT-042-BLE-A to the CYBLE-214015-01 module?
PSoC 4 MCU
Hello @jay_aechh ,
You will need CYBLE-214015-EVAL EZ-BLE Evaluation Board that is designed to fan out the connections of each respective CYBLE-214015 Module to headers compatible with the CY8CKIT-042-BLE-A Pioneer Kit.
Refer to Section 6 in this Application Note to understand how to set up the module on the baseboard.
To debug your PSoC Creator project, connect the baseboard, with the PSoC 4 BLE module, to
your computer with a USB cable and follow the steps mentioned in Section 9.5 on Page#95 from this Application Note.
Hope this helps 🙂
Dheeraj
Hello @jay_aechh ,
Hope this helps 🙂
Dheeraj
