I'm new to PSOC usage. I have been assigned a completed project to update. It has been compiled for a CYBLE224110-00 MODULE, but I want build and upload it for a CY8CKIT-042 KIT.
I loaded the project and went to device selection, but I only see options for MODULE items and I don't see any options matching anything I could see printed on the KIT.
Does the KIT have an associated MODULE within it I could select? What would be the process for bringing up a pre-built PSOC4 project built for a specific PSOC4 BLE MODULE using the CY8CKIT-042 KIT?
PSoC 4 MCU
In Device Selector, please select the PSoC4200 Series as shown in attached image. Please check the supported components in CY8CKIT-042 PSoC 4 pioneer kit. And, disable the unsupported components and functions to work.
P Yugandhar.
RideMaker,
I don't know if this is helpful. To visualize parts and components on the CY8KIT-042 (Creator only) one can use:
KIT-042: annotation component for CY8CKIT-042 Pioneer Kit
In the Device Selection, you should pick CY8C4245AXI-483. I don't believe there is any MODULE selection in Creator.
/odissey1
