We wanted to know if we can program the CYBLE-022001-00 BLE beacon sensor with codes in this directory https://github.com/Infineon/PSoC-4-BLE/tree/master/100_Projects_in_100_Days.
We tried running this code https://github.com/Infineon/PSoC-4-BLE/tree/master/100_Projects_in_100_Days/Day008_Constant_Broadcas.... in BLE beacon sensor (CYBLE-022001-00 BLE beacon) but it was not working with it.
Can you please help us in this?
Thanks & Regards,
Kavan Mehta
PSoC 4 MCU
Default codes for the BLE beacon sensor optimizes current consumption. Please refer to the below points, if you want other codes to work.
1. Please refer to the sections '5.2 Firmware Description' and 'A. Advanced Topics' from the CYALKIT-E02 Kit Guide.
2. Refer to AN213948 - Basic Concepts for Energy Delivery with S6AE101A, S6AE102A, and S6AE103A.
3. Refer to AN210772 - Energy Calculation for Energy Harvesting with S6AE101A, S6AE102A, and S6AE103A.
P Yugandhar.
Could you please let us know the issue which you are facing with this project ? Please send some screenshots or logs for checking the problem.
P Yugandhar.
I am not able to see the Bluetooth address of the ble beacon sensor (broadcaster) in the cysmart window.
Thanks & Regards,
Kavan Mehta
The dynamic broadcaster code https://github.com/Infineon/PSoC-4-BLE/blob/master/100_Projects_in_100_Days/Day009_Dynamic_Broadcast.... is working with PROC mode and EZ-Ble mode but when we remove the ble beacon from the debug board we are not able to see the Bluetooth address (dynamic broadcaster) in the cysmart app.
We tried giving the solar power with the light source but it did not work.
Thanks & Regards,
Kavan Mehta
You can program and use with USB power but it can't work with solar energy. You need the USB power to work.
P Yugandhar.
Actually the default code i.e. the code provided in kit CYALKIT-E02 (attached in the attachment) is working correctly with the ble beacon sensor i.e. values are being displayed in cypress ble-beacon IoT device solution app without attaching it to debug board after programming it.
But the code mentioned in previous chat is not working with ble beacon sensor after removing it from debug board.
Can you please tell the reason why its working with default code and not with other codes?
Thanks & Regards,
Kavan Mehta
P Yugandhar.
