Hi all,
I use PSOC Creator 4.3 create a demo project for 4147AZS-S475, and system clock settings as blow,
I can use PSOC Creator 4.3 debug the demo, it's OK. Then I export the demo to IAR, but IAR debugging is failed. Errors occur while initialize system clock, if codes enable EXCO, the debug is failed.The code is shown blow,
It's so strange, if I download code to chip using IAR, it can run well. But I can't using IAR debug the code.
While debug failed, IAR shows CPU status FAILED,
I guess, IAR can't connect to MCU when enable EXCO. How can I fix the error..
Best Regards
PSoC 4 Architecture
Hi yuyu_4712591,
Can you let me know the debugger that you are using?
Were you able to debug the device when ECO is disabled? If that is the case, did you also disable PLL?
Also, can you please share the screenshot of the debugger settings? What is the reset mode that you have selected? Please refer to this KBA and let me know if it helps - Debug pointer does not reach main() when using Keil uVision and ULink2/Ulink Pro Debuggers - KBA2299...
Thanks and Regards,
Rakshith M B
Rakshith M B
Hi yuyu_4712591,
Thanks and Regards,
Rakshith M B
Rakshith M B
