PSoC™ 4 Forum Discussions
        I just upgraded to 3.0 should PSOC 2.2 be removed? If so what is best way?
        I should have said Creator 3.0 from Creator 2.2
BrCr_300591
 I left Creator 2.2 installed. It seems to coexist fine with 3. You can run 2.2 through the start menu.
I keep Creator 2.2 installed as Creator 3 removes support for a few devices. If you own an ES silicon dev board or psoc5 board you will probably want to keep a copy of creator 2.2
You can unistall creator 2.2 using the Cypress Update Manager
Keep both. As mention from other memebers, some devices were removed. Would be a headache if you need to support those devices. But if you use if just for learning or with new projects. Use the creator 3.
rotec_264361
In the past the rule was that you can keep major revisions installed in parallel while a new minor revision will replace the previous one.
hth
