meron
11:32 AM
- Email to a Friend
Hello everyone,
Is there a way to define two Bootloaders, a PRIMARY bootloader that loads/upgrades the APPLICATION and a SECONDARY bootloader that loads/upgrades the PRIMARY bootloader?
In different words, I'm looking for a way to be able to upgrade a Bootloader project in the field.
Currently, once a Bootloader project is out there, it is possible to upgrade the APPLICATION only in case the Bootloader project was not changed, which is a major problem in case the Bootloader contains bugs or more features are needed.
Thanks a lot for your help,
Meron
09:53 PM
- Email to a Friend
Hi @meron ,
Please refer to the below document under the section 'Use Cases' where you can find bootloaders and their use cases.
Alakananda
meron
12:37 AM
- Email to a Friend
Thank you, but I don't understand how it solves the problem. I'm not looking for a single bootloader to load two different applications, but two bootloaders and a single application. One bootloader, the primary will load the application. Another bootloader, the secondary will be responsible of upgrading the primary bootloader.
Meron
Meron
