I've bought the PSOC 4 BLE device development kit. I want to take the small BLE device out from the base. Is it possible? If so, what are the voltage that supply enough power to run the small BLE device?
Thank you!
BLE
1.71v to 5.5v without BLE radio, 1.9v to 5.5v with BLE radio. (Any coin cell, AA or AAA battery should work )
You will probably want a 1.0 uF cap on the power supply pins.
Reading these documents: http://www.cypress.com/file/137466/download , http://www.cypress.com/file/141171/download
should answer your questions you have for using the PSoC 4 chip. page 47 of the second document (Getting Started with PSoC 4 BLE) describes the voltage range, and page 16 of the first document (PSoC 4xx7_BLE Family Datasheet) describes a simple setup for the chip standalone to have it operate (The bypass capacitors listed on there should be what you want)
