I'm using PRoC BLE module on CY8CKIT-042-BLE Pioneer Kit.
I have all day searched for decent UART Interrupt example but without success. All I found were cases where UART was used for debugging purposes, or USB-UART bridges... I want to utilize UART component as a communication path to my microcontroller.
Basically, I need UART parser on input data which will raise an interrupt. I found similar example but with UART component v2.50. In my case I can only use UART SCB component (v3.50), but it's different, command are different and investigating so much time in basic UART is now something I haven't time.
Is there a similar project out there that could serve as a good starting point?
BLE
There is a Uart program here https://github.com/cypresssemiconductorco/PSoC-4-BLE/blob/master/100_Projects_in_100_Days/Day020_BLE...
It allows flow control but this is not usable with the cypress Kit prog USB connection.
