POSC PROGRAMMING
Cypressresolv
Hello, thanks to supporting me,
I Program a CY8C4014LQI-421  (PSOC 4) with the PSOC programmer and PSOC miniprog3 and the target device was not well choosen. The target indicated was CY8C3666AXI-037T (PSOC 3) .
I did not see the difference using the target card, software response is correct .
Could you precise to me if the target device influence the programming in this case ?
NB : I didn't have any error message.
Thanks for your help.
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hi @Cypressresolv
Can you please let me know if you are referring to the device that is detected as shown in the snapshot below (highlighted in red)?
Also, have you enabled AutoDetection (highlighted in yellow)? If so, you need not be worried about the device and device family. Your device will be auto-detected by PSoC Programmer.
Thanks and Regards,
Rakshith M B
Rakshith
Hi @Cypressresolv
Thanks and Regards,
Rakshith M B
Cypressresolv
I validate your hilight, thanks for your prompt answer.
