Greetings - need to transfer 80KB firmware data from an EEPROM (M24M01) to a ST VL53L5CX ToF sensor utilizing a PSoC 4200 series (cy8c4245azi-473) and have a couple Qs?
1. Since I'd be reading, then writing data in chunks, from a PSoC point of view is there any magic number for an optimum buffer size that woks best with the I2C HW?
2 The I2CMasterReadBuf() and I2CMasterWriteBuf() functions... I went through the examples looking for some guidance and came up empty. I assume I'd still be required to precede those functions with the typical Start/WriteRegisterAddr/etc commands?
TIA,
Terry
Hi @TePh_4811091,
The I2CMasterReadBuf/WriteBuf are high-level APIs and they will internally invoke the I2C start etc. You can check the I2C Master High-Level code example as a reference for your application.
The component datasheet will give information regarding the API -
Regarding the buffer size, I think you can use the row size as the buffer size for your particular explanation.
Hope this helps,
Rakshith M B
Hi @TePh_4811091,
Hope this helps,
Rakshith M B
