DaHu_285096
10 likes received 250 replies posted 100 replies posted
I have a simple project that just uses a UART and Timer and several IO pins but I cannot compile as it has run out of UDB resources.
The timer just needs to prove a 1ms interrupt but I am having trouble getting it to run.
I have attached my project.
Would be good if there was a method to generate 1ms timer int with less resources.
Any help much appreciated.
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Beta tester First comment on KBA 1000 replies posted
> Sorry, I should have posted interim result.
That's OK, I do similar things all the time.
I saw your schematic and made a couple of modifications
(1) Reconnect ISR to interrupt pin
(2) Enabled the TC interrupt
I hope with this the interrupt will be called.
BTW, if all you needed was a 1 ms periodical interrupt timer,
you could have used "SysTick." And using it will not consume UDB resource.
Following URL is my sample using SysTick.
Measuring time interval using SysTick (CY8CKIT-059/CY8CKIT-044)
moto
MotooTanaka
Level 9
Level 9
I just downloaded you project and duplicated the project to "Remote_Sensor_200430A".
And it could be compiled without problem.
Would you try "Clean and Build" your project?
And in case, you still have the problem please double check if the attached project was the same one.
moto
P.S. Attached is the project I duplicated and compiled. (now cleaned and archived)
I changed timer from 32bit to 8 bit and it compiled
However, when I run the code I do not get any timer interrupts occurring.
I enabled global interrupts before calling the Timer init routine in timer.c
I then start the timer component and hook up the isr to msTICK_INT, but this interrupt never gets called.
MotooTanaka
Level 9
Level 9
moto
Thanks Motoo,
I'll take a look at systick, That is all I need, a 1ms periodic interrupt.
