Equip yourself to optimize PSoc4 MCUs for Evs at the EV Webinar. Click here to register.
PSoC™ 4 Forum Discussions
Giannis
10 sign-ins First question asked First reply posted
Hi friends,
I use CY8CKIT-059 PSoC kit for my projects.  I need more code information about how to handle with the WaveDAC8 component.
I need to understand better the functions of this component in order to re-configure the DAC under a progrtam loop.
My application is to generate a periodic sinus waveform from 3kHz to 5kHz... The examples I found have only
WaveDAC8_Start() as example.
Kind regards /Leonidas
Selefkos
odissey1
Level 9
Level 9
Leonidas,
One way to vary sine frequency is to adjust WaveDAC sampling clock using DDS generator. You can find examples of using DDS24 AND DDS32 components here:
DDS24: 24-bit DDS arbitrary frequency generator component
/odissey1
P.S. Wrong forum.You can get better response by using PSoC 5 forum
odissey1
Level 9
Level 9
Leonidas,
/odissey1
Thanks friend. It was helpful.  Br/Leonidas
Selefkos
