公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
奥特曼
您好,技术管理员。当我使用MiniProg4时,插入USB后,我发现该设备无法配备。故障现象为:模式指示灯闪烁,错误指示灯常亮。帮我看看问题是什么谢谢
0 点赞
1 解答
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
Because you press the custom APP button to enter the "Custom APP" mode.
More you can refer to the Minprog4 user guide.
在原帖中查看解决方案
0 点赞
3 回复数
LinglingG_46
你这个是新的吗?
之前可以用吗?
从资源管理器里面能看到被枚举了吗?
你是否存在vdd和gnd短接的情况?
如果用cypress programmer是否可以升级?
按Mode Select 切换模式,现象是什么?
0 点赞
奥特曼
Hello, this is a new device. It has been used normally once before. After a failure, the USB cable is plugged in and the computer does not recognize the serial port. After pressing the Custom App button for 3 seconds, the device returns to normal, but the cause of the failure is not clear. Thank you for your reply. Thank you
0 点赞
LinglingG_46
0 点赞
