PSoC™ 4 Forum Discussions
奥特曼
您好,技术管理员。当我使用MiniProg4时,插入USB后,我发现该设备无法配备。故障现象为:模式指示灯闪烁,错误指示灯常亮。帮我看看问题是什么谢谢
Because you press the custom APP button to enter the "Custom APP" mode.
More you can refer to the Minprog4 user guide.
LinglingG_46
10 questions asked 5 questions asked 250 sign-ins
你这个是新的吗?
之前可以用吗?
从资源管理器里面能看到被枚举了吗?
你是否存在vdd和gnd短接的情况?
如果用cypress programmer是否可以升级?
按Mode Select 切换模式,现象是什么?
奥特曼
Hello, this is a new device. It has been used normally once before. After a failure, the USB cable is plugged in and the computer does not recognize the serial port. After pressing the Custom App button for 3 seconds, the device returns to normal, but the cause of the failure is not clear. Thank you for your reply. Thank you
