I have a design which uses the CAN controllers in a PSoC 4200L. The datasheet for the component says that when the Bus-off restart option is set to Manual, if the bus is turned off, the user/code must restart the CAN. What exactly needs to be done to restart the CAN component?
I am testing restarting the CAN by enabling Message Transmitted, Message Received, and Bus Off interrupts, then shorting the CAN low and high wires, then sending a message. I get a bus off interrupt, then try to restart the CAN using the CAN_Enable() API function (CAN_Init() and CAN_StartEx() were called during initialization). After the bus off interrupt stops firing (after 3-4 calls to CAN_Enable()), I un-short the low and high wires and try to send another message, but I don't see any messages on the bus using a logic analyzer. Is there something more I need to do other than call CAN_Enable() to restart the CAN?
PSoC 4 Architecture
Hi David,
You can use CAN_Start() for restarting CAN after bus off.
Can you try it at your end?
Harshada
Hi David,
Harshada
Hi Harshada,
Thanks for your reply.
I reworked our initialization code to call CAN_Start() (rather than CAN_Init() and CAN_Enable() separately), then call CAN_Start() to reset the CAN component, and I see messages on the bus now. So, I think the issue is resolved.
