公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
zoe00
10 sign-ins First reply posted First question asked
Could you provide a routine that can be used in the PSOC4100S PLUS and other similar demo boards?
0 点赞
1 解答
LinglingG_46
500 solutions authored 1000 replies posted 10 questions asked
Please refer to the proximity code example in PSoC Creator IDE. The MTB doesn't offer the proximity code example until now.
The related application refers to the linker:
 https://www.infineon.com/dgdl/Infineon-AN92239_Proximity_Sensing_with_CapSense-ApplicationNotes-v03_...
在原帖中查看解决方案
0 点赞
3 回复数
LinglingG_46
I am sorry for a bit confused about the "routine",  what do you want?
If you mean the test code, you can refer to the MTB code example about the CY8CKIT-149.
https://www.infineon.com/dgdl/Infineon-CY8CKIT-149_PSoC_4100S_Plus_Prototyping_Kit_Guide-UserManual-...
0 点赞
zoe00
MTB don't  have proximity test code,i want proximity test code can be use in cy8ckit-149 or cy8ckit-145, thanks
0 点赞
LinglingG_46
0 点赞
