GrWa_2302706
Level 4
Level 4
50 questions asked 25 replies posted 10 replies posted
Hi
Below is the captured waveform of MBR3116 CS0 pin, which is connected to a sensor.
It shows a frequency-changing waveform. Is that coz MBR3 uses PRS clock?
Could the clock frequency be decreased by modifying some setting parameters of MBR3?
BR
Grace
BragadeeshV
Hi GrWa_2302706​,
Yes, MBR3 uses PRS for sense clock. The parameters are set by SmartSense and can not be modified.
Bragadeesh
Bragadeesh
BragadeeshV
Hi GrWa_2302706​,
Bragadeesh
Bragadeesh
Hi Bragadeesh
Is MBR3 always in SmartSense even though automatic threshold is disabled ?
Another question is that why automatic threshold should be disabled when median filter is used.
BR
Grace
Hi GrWa_2302706​,
Yes MBR3 device operates only in SmartSense mode.
The RAM available in MBR3 devices is limited therefore enabling median filter and auto threshold will cause RAM overflow.
We recommend you to evaluate PSoC 4S  devices (4000S , 4100S ,4100S plus) that has latest gen CapSense and is programmable.
Bragadeesh
Bragadeesh
