Fayne_Meng
Level 4
Level 4
Distributor - Weikeng(GC)
100 sign-ins First like received 10 likes given
    4127工程报如下错误如何解决,谢谢。我这边已经尝试过重新连接clock组件和timer组件,还是会报错;
M0050:Terminal "clock" requires connection when it is visible.
Fayne_Meng
Level 4
Level 4
Hi Roy,
     问题解决了,关掉软件重新打开编译一下又好了。谢谢。
Roy_Liu
First comment on KBA 10 questions asked First comment on blog
最好把 工程(如果设计敏感信息,可以删掉和此问题无关的代码和组件)贴上大家看一下问题在哪里
Roy Liu
Fayne_Meng
Level 4
Level 4
Hi Roy,
