I'm creating a new project using CY8C4125AZI-M433. I have made a couple of clocks and attached them to the clock input of a few components (PWMs, Timers). However, I keep receiving the above error. I don't know what a dsi_out is, the clocks are only going to dedicated component clock inputs. I even tried disabling a few pages to see if I just had too many PWM components, but that didn't seem to help. When I check the resource meter it shows that I'm using 0 digital clocks, I would expect that after adding 2 clocks something would show up there. Am I missing some setup step?
PSoC 4 MCU
I've found what is causing the error, however I do not see a way to fix it. When playing around with the clock setup, I noticed I added the clock in question to one of the System DigSig1 clocks. Unfortunately, there is no way to de-select (clear) a clock after it has been selected in the popup dialog (not the checkbox, that works fine). The work around I found was to delete that clock and use a different name. Now the clock in question doesn't exist and the error goes away.
